Hi, my Robot Tank starter kit has just stopped moving in all directions, the motors don’t seem to be turning, it has power but nothing works.
Is there a way to reset to “Factory Settings”?
Thanks
Robot tank starter kit just stopped
phil57
Nesio
Yes you have to hook it up to your computer you can install firmware using mblock. when editing in arduino and provided you installed the libraries you can go to sketches libraries makeblock starter en select for instance the ir_ultrasonic to get ir working again and so on.
phil57
Hi Thanks, for that, I did get it going after following another thread, your solution is a much simpler way to achieve the same end.
Thank you for taking the time to help me
