Hi all,
My RGB line follower works when it’s in upload mode but when I connect it to mBlock via 2.4 GHz the RGB line follower doesn’t work.
Connecting via bluetooth also has the same issue.
The idea is to give instruction to mBot via sprite to line follow and turn on a certain junction based on the instruction from the sprite. I.e. if I input 1, the mBot will turn on the 1st junction, if I input 2, the mBot will turn on the 2nd junction etc.
Any help is appreciated.
