Problem using stepmotors and bluetooth [solved]
Im having some problems using two (or one) step motors and bluetooth.
I wrote a function to contol two of them, it looks like this:
void moveTo(int x, int y)
  stepperX.moveTo(x);
  stepperY.moveTo(y);
  while(stepperX.currentPosition() != x || stepperY.currentPosition() != y)
    if(stepperX.currentPosition() != x)
      stepperX.run();
    if(stepperY.currentPosition() != y)
      stepperY.run();
It works perfectly, the problem is, after I make the call:
bluetooth.begin(9600);
edit:
I traced it one step further, its after Me_BaseShield::begin(); that it stops working.
the motors wont move. If I read the value from stepperX.currentPosition(), it seems to think its moving.
Anyone got an idea of what might be wrong?
Thanks
Johan
Soved it, im not sure if this is a correct solution, or if bluetooth work.
But after bluetooth.begin(9600);
I added:
stepperX.enableOutputs();
stepperY.enableOutputs();
This will cause
pinMode(_pin[2], OUTPUT);
pinMode(_pin[3], OUTPUT);
to be rewritten, they were overwritten by Me_BaseShield::begin();
Will test some more when I get the time.
Good to know you solved it by yourselves. Bravo!
Yes, it seems to be working fine now.
