Problem mBlock IOS and Bluetooth
Hi Makeblock,
Bluetooth with the mBlock v1.7.0 application under IOS 13.3 is not detected, is this normal ??? It worked since I did all the activities up to the LOOP section.
Bluetooth with the mBlock v1.7.0 application on Android is very well detected and I can use my Codey.
Thank you
Unable to use mBlock required by Makeblock app
Hi, I have IOS 13.3, and mBlock V1.8.2 works well with it. Have you tried to update the mBlock to the latest version?
I continue on this post: Post
Hi Crackel
Try to update your iOS to the latest version to fix the bluetooth issue. Or try to use an iOS system recovery software.
