Problem card(map) me orion
Hello on our kit robot tank when we connect the card me orion on the PC by cables him this one work well, but when we light the card without connection all the leds flashes we have to try of everything to prune, to update the microphone schedule but nothing can be done … thank you for your answer.
Cordially je
Thierry
Hi Maudet,
Do you mean Your starter robot works ok with USB cable connected while doesn’t work when removed the cable.
Were you trying to upload some program to the robot? If yes, what is your program?
Besides, you may upgrade firmware for the starter and then reset default program have a check. Please refer to these instructions.4. How to upgrade firmware for starter.docx.zip (1.1 MB)
2. How to reset default program for starter with mBlock.docx.zip (1.0 MB)
If still the samething with the default program, then please change the battery have a check. According to our test and research, it is suggested to use rechargeable Li-ion battery or rechargeable nickel-metal hydride, nickel-cadmium which can be bought from amazon or local shop. Or Alkaline battery with good quality like Energizer, DURACELL.
Great we thank you for this information…
The problem is solved we continue to discover his(her,its) possibilities!!
