Plotter drawing unexpected circles
Hello Makeblock,
I’m learning how to use the XY Plotter (v1) with a mac os computer. Everything seems ok for straight-line drawings (G0 and G01 gcode commands). But when drawing arcs (G02 and G03), strange and unexpected circles appears frequently.
I give you a code example :
G90
G00 X 99.9766 Y 75.0199 Z 0.0000
G03 X 100.2899 Y 73.0513 Z 1.0000 I 62.8027 J 8.9836
where the third command line produces a circle where it must draw a tiny curve.
I check my gcode with Gwizard and I cannot see the problem !
Please, answer me ! I need your help !!
hi,@Niko,have a try to use the v2’s software?, https://github.com/Makeblock-official/XY-Plotter-2.0/tree/master/software, it’s an Processing program.
Hi robotfan,
It seems interesting. I’m trying actually to launch it on my mac.
But I don’t think it will solve the problem, because when I send an example of a “wrong” command line (see my last post) with arduino serial monitor, the same bad circle appears. So I don’t think the problem has something to do with plotter controller application but maybe with the arduino sketch of the V1 plotter. And as I am not a specialist in code the problem is not easy for me to understand… Rrrr…
Hi there, I have tried using this new V2 GCode parser and the movements are a lot smoother, the only problem is I cannot get the X axis stepper motor to communicate with my stepper motor driver (2H microstep) Is this something to do with a different pin layout on the Meduino compared to the Me-Baseboard?
Do I need to re-map pins?
Any help will be greatly appreciated as the version 1 of the software is rather glitchy
Regards,
L
