Out Power set at 8% in settings... what does it mean?
Out Power set at 8% in settings… what does it mean ?
Do we need to change it ? What is the impact ?
Thank you !
Hi PascalLevesque,
Actually I’m not sure about the issue, could you please send me a screenshot of the error message?
Also please share me the model of your robot.
Thanks.
Take a close look at the categories that @PascalLevesque has attached to this topic. Apparently it’s a topic about laserbox.
And I think @PascalLevesque probably talking about this image.
Yes, you’re right !! This option is in the settings of LaserBox software !
At first, I had some performance problem with my unit. But, after cleaning laser head, it was a lot better !
But, I would like to know if we need to change this settings (15% max, 8% default)
Hi PascalLevesque,
Out power refers to the minimum duty cycle of laser emission. The laser isn’t emitted continuously but at intervals in a specific cycle. The fraction of time of laser emission during a cycle is duty cycle. When the duty cycle is lower than a certain value, the lasers fail to come out. Out Power allows you to set the minimum duty cycle to ensure the normal laser emission. After Laserbox operates for a long time, a certain level of power loss occurs. In this case, increase Out Power to offset the loss.
NOTE: Adjust Out Power only when the laser emission goes wrong.
By the way, this settings related to the offline working.
