Numeric keypad won´t work on mBlock (3.2.2)
Hi, some days ago I updated my mBlock to 3.2.2 and the numeric keypad of my keyboard stoped working.
for example, if i put, “when a key pressed” “move 10 steps” it works. But if I change “a” for “2” it only will move if y use the keys I have above the letters but not the numeric keypad.
I don´t know if this is because the update or is becase of my computer. If someone has had the same problem or know how it can be solved, i´ll apreciate it.
The numeric keypad works perfectly in any other things and the bloq num key is working.
thanks for your help!
Did you upgrade the firmware? My experience is that when I update to a new version of mBlock, I need to upgrade the firmware and I usually load the default program for good measure.
Yes, I have tried both ways, upgrading the firmware and the default program too and it doesn´t work.
Just to be clear here, is this your line of code?
yes, in my case, the panda should move but it doesnt work.
That’s odd. Is the code in the Panda sprite, not in the Stage?
yes, it works when I use the number 2 I have above the letters q and w but not when i use the numeric keypad.
If you have full standard keyboard then check your keyboard NumLock key status.
If it’s active then numpad keys act like numbers otherwise they act like arrows,home,pgup,end,pgdn.
yes, I have checked the numlock key status. I think it will be my laptop. I try the same code on scratch 2 and it works perfectly. thanks for all your help!!! if someones know how I can fix this, reply this thanks.
Now i tried it and yes, you’re right.
The numpad is not working the way you’re using in project.
Doesnt matter what state the numlock key has.
It’s probably mBlock bug.
