Network Connect Mblock
How do you use the broadcast and receiving function to communicate between computers for multiplayer games? My mblock says it’s connected. I’ve followed the instructions here- http://www.mblock.cc/posts/multiplayer-with-network
Which robot are you using? I’m not sure that the mBot, for example, can do that.
@tec_support can you confirm my observation about the mBot?
I’m not using it with a robot right now I’m just using the network connect feature in mblock to connect to mblock on another computer
Hi Charles & Bill_W,
The network function under mBlock won’t work with robots since it is impossible to connect to the robot when the mBlock is connected under Network.
Actually, the network function is seldomly used and this part function may not mature. It is not suggested to use the Network under mBlock.
Is there something special I need to do to get it working though?
