I am running Yosemite. I cannot get the bot to connect via bluetooth or USB. Could anyone provide step by step instructions for this? Thanks!
Need help with bluetooth on a Mac
You will need to install the current signed driver (link) which should work with Yosemite before OS X will see the serial port. Afterwards, it’s a good idea to upgrade the firmware. That’s pretty much all I’ve done to get mine working with mBlock 3.2 and the mBot on OS X El Capitan.
I can’t help you with the Bluetooth because my mBots are all 2.4GHz WiFi.
oxygen
and do not forget to update to the latest version of mBlock (http://mblock.cc) and when that is installed upgrade the firmware (from menu)
