https://extservice.mblock.cc/ will return Not found
unless used with a path, like /path/to/extension/
. It’s the API that serves extension and device data, including images, files, names, blocks JSON, and more. If you think you are having issues connecting to it, make sure it isn’t blocked in your firewall and try from another device as well. @bpwl
Need help adding device without Internet connection
Best_codes
#21
bpwl
#22
they need an empty project (.mblock file, local save of project) just with the mRanger loaded as device, as a workaround, I guess.
Best_codes
#23
@everyone I can contact you with mBot Ranger’s .mext
file so you can use it in mBlock (5.4.0 only!) if you need.
system
#24
