Hi There,
I got two m-bot ranger , wondering if these two bots can communicate to each other. any expert advice much appreciate thanks in advance
Regards
D
Hi There,
Regards
D
Sorry, only mBot support that. Ranger doesn’t.
We need the below blocks:
Here is an example, mBot A:
mBot B:
You talked about Mbot “Ranger” not Mbot
The example given by support doesn’t work with “Ranger” !
The block “send mBot’s message” wich correspond to sendind infrared message is not avaliable for Ranger
Dear Experts ,
Appreciate your response , so does that mean there no function available for two or three ranger to work in coordination. I need work on project where I can leverage multiple ranger to work in coordination and exchange a command like peer to peer coordination
Cheers
D
Seems to be impossible to send IR message with scratch from Ranger board. You can just listen signal.
I recently developped un project to coordinate 2 boards with IR messages (please see show-case “ranger dual brain”) by it works with Mbot board sending message to Ranger board.
It’s possible to communicate between 2 auriga board by another “roots” way , like sending sound, light or contactors but it’s not accurate … maybe the best way to do is to use Wifi module but I can’t help you, sorry !
