Using mlink on chromebooks and a pc with my students. Worked fine until about 2 weeks ago. Cannot put a variable in a motion block command. Cannot put sensor value into led display using show number. I get the error message as below. Also cannot use bluetooth controller code specifying joystick. Everything works if I use pc mblock version 5.3.5. mlink version suddenly seems to handle numbers differently. Cannot change number type. Is this a “server side” problem on your end? I am using the latest mlink version 2.1.1
In the png file of code, i receive the upload error when I use variables such as left and right in the motor command. If I replace variables with actual number like 25 it works. Is this a variable type error?
Like I said this was niot happening about 2 weeks ago. I have noit heard anything from an email to tech support. I am trying to help students. Thank you.
