I have a little problem with my MeCompass sensor that I connected to the MeAuriga baseboard. Even though I press the button, the blue LED only flashes 2-3, but it does not switch to continuous flashing, so I cannot calibrate the device. I uploaded the test program from the MakeBlockDrive directory of the Arduino IDE and I do everything as described, but the module does not switch to calibration mode. I’m waiting for help and advice. Thanks!
MeCompass calibration problem
Hi:
Did your sensor exceed the warranty? if not,you can contact with local distributor to replace or fix this module.
system
