ME Wifi don't work anymore
I connected my new ME Wifi module with my Starter Kit. I could configure it through the web page and it works for a short time with the Wifi example sketch and USR-TCP232-TesT. But I was not able to connected it to my router. After storing the password I was not able to connect anymore (not to my network nor to the Wifi module AP).
Here are my questions:
  • is there a way to reset the Wifi settings to the factory values?
  • can I reprogram the wifi module with the original or different firmware?
  • is it possible (and how) to use the Wifi module direct with a TCP port (without USR-TCP232-TesT) ?
Thanks for any ideas/pointers!
Michael
There is a switch Prog / Work mode - if you select it to Prog then wifi module should restart , once you put it to Work mode you should see Wifi with module name.
Hi all,
Here are the steps to reset me wifi module in details:
1.Put the swtich on WORK side. The blue light blink slowly.
2.Unplug the RJ25 cable from WiFi module to power off it
3. Plug in the RJ25 cable to WiFi module to power on
4. Pull the switch to PROG side.
5. Wait for a while, normally, the blue light will quick flash.
6. Then pull the switch back to WORK side and restart the WiFi module by unplud and replug the RJ25 cable from WiFi module.
