When I compile the demo Code for MeCompass with Makeblock Library V 3.0 the Code will run but the Sensor won’t leave the calibration mode.
The cause is that dRead1(INPUT_PULLUP) will always give the value 0, even if the button is pressed nor not. The voltage at the key pin of the module is changing. So I think there must be a Software error.
Is there a solution for this problem?
