Me Audio Player
Does anyone have any experience with this module?
http://store.makeblock.com/me-audio-player-v1
Hi rojoamigo,
Is there any problem for you to use it?
Here is an instruction with some simple program examples for it to you for reference.Me Audio Player User Guide.zip (270.0 KB)
Hi Tech:
Thanx for the reference doc. It seems that I would have to add an extension. Does it work on (mcore, orion, Auriga, megapi)? I have mcore, orion and megapi.
Since this module appears to be only available from China, I would have to:
  • order it from you OR
  • pay a distributor to order it for me in their next order (6 weeks)
Also your modules do not seem to work on all makeblock platforms (mcore, orion, Auriga, megapi) and therefore it would be nice to hear from other users. This also is the case for the color sensor and the line follow array.
Hi David,
Yes, it works with the mBlock extension. This extension works with all our mainboards with RJ25 Port.
Since the color ID on the Audio Player is white (means it communicates through I2C), you can connect it to any RJ25 Port with white ID (the RJ25 Ports supporting I2C communication) on the mainboards.
As for the order, I am not very familiar with it. Here listed all the purchasing route of our products to you for reference. You may check with your local distributor and see if they sell this module. If the local distributor doesn’t sell it, you may buy it from our official website directly.
