Mcreate doesn't read files
Hi! I’ve recently purchased the Makeblock Mcreate 3d printer and PLA filament. After putting it together I downloaded Cura and installed the Makeblock Cura Plugin, and then I have run into an issue. The Mcreate will not read any files on the USB I put into it. After saving print files onto the USB from Cura, I will insert the USB into the printer and the printer will not see any files on the USB. I can’t print anything. At this point, I haven’t been able to print a single thing yet. I am at a loss on what to do. I have tried 3 different USBs and two different computers and nothing changes. Please help!
Have you tried seeing if the USB is on lock? Also, try saving the .gcode files to the USB manually instead of through Cura.
If you need more help, mention me as @Best_codes.
Thanks for your time,
Best_codes
