[mBot2] "encoder motor EM2 rotates at" make wheel rotates wrong direction
mBlock PC version v.5.4.3 + mBot2
When I’m using the “encoder motor right wheel EM2 rotates at 30%” block it make the right wheel rotates BACKWARD!
However, for the left wheel (EM1) the same block works fine - it moves mBot2 forward.
And when I’m using the “move forward” block, the mBot2 moves forward as well.
So, the problem happens only in the first case.
Am I the only one with this problem?
@IgorVasenko No, you aren’t the only one with this problem. It’s an annoyance that hasn’t been fixed.
An easy workaround is to just use a negative value (e.g., -30%) instead.
