I came across a ton of SG90 servos that a friend of mine no longer needs. I have a bunch of mBot2 kits.
Is there any way to use SG90 servos with the mBot2 ?
The mBot2 has two servo ports and I see they are 3 pin. So could any Servo connect to it? I’m guessing one is Signal , GND and Power. I would think the pin orientation is reflective of all Servo pin orders.
In any case I also see two other Misc ports on the mBot2 is this an alternative place for more servos? Or could I use an actuator here? Or perhaps can I use actuators in the servo ports?
Thank you
