The Mbot will perform inconsistently when making the right turns in this code. It will move the same for each forward block, but it will not for the right turn blocks. The first right turn is at 90 degrees as intended, the remaining right turns are plus or minus 30 degrees from a 90 degree turn. We are trying to get the Mbot to complete a square with its movements. I have also tried using a repeat block but it still performs the turns inconsistently. Any advice would be appreciated!
Mbot will not execute command consistently
system
