Mbot tank
I buy mBot v1.1 kit. I want to transform mbot into a tank.
What can I add to use “Track With Track Axle” ?
Best regards,
Anthony.
You’d need to do a design to figure out the beams, gears, etc. needed to make that conversion. I can tell you that you will likely want to have three gears on each side (one for the motor, a front wheel, and a tension wheel). With regards to which beams, you’d need to design the vehicle and see what parts are available in the Makeblock store. :-/
