mBot RGB LED does not change color
I’ve just assembled and started programming the MBOT via android device app. When it starts up the RGB LED flashes red and green. Then it settles on white. I cannot get it to change to the programmed colour via the app (it just stays white). It does everything else (movement and sound).
Any ideas?
@ssss2 Do you know what version of the app you are using? Also, are you using the mBlock App or the Makeblock App (they are separate apps in the App Store.)
