Mbot Ranger drive and than he stops than he peeps and repeated the howl again
Hi i have becom a Mbot ranger to Christmas. I have construct the bot and it works perfect. After one or two days he do stops and beeps and load all again… After about 40 he stops again. This circulation repeats always.
I Need Help !!! PLEASE!
(My English is not very well :slight_smile: )
Replace batteries?
I have replace the batteries but it doesnt work better.:disappointed_relieved:
Hi Joel,
What’s kind of batteries do you use?
It is suggested to use rechargeable Li-ion battery or rechargeable nickel-metal hydride, nickel-cadmium which can be bought from amazon or local shop. Or Alkaline battery with good quality like Energizer, DURACELL but these non-rechargeable batteries may not last long since ranger is a high power robot which consume the power in the batteryquickly.
Once still doesn’t move after changed the batteries recommended, please upgrade firmware for the robot have a check.How to Upgrade Firmware for Ranger.zip (358.3 KB)
Hi tec-support
Thank you very very very much i think ist that problem…
Now i replace the batteries.
I thank you very much!!!
:joy:
What is this for a Firmware?
Hi Joel,
Yes, that is the instruction to upgrade firmware.
If you control the Ranger robot with Makeblock APP, I think you can reset default program for the ranger with latest version mBlock 3.4.5, please refer to this instruction insteadHow to Reset default program for Ranger.zip (411.1 KB)
Once still the same issue after you tried all above, please kindly take a video to show the issue on the Ranger robot.
