My Mbot Meqa doesn’t work when I unplug it. The code runs and everything works fine when plugged into the computer and when I unplug it from the computer the lights change but the motors seem to not respond. When the motors respond they move maybe like an inch and nothing else. Yes I’ve tried new batteries I don’t know what the problem is.
mBot Mega motors not turning when unplugged
@Addon2
Just making sure:
- The mBot Mega switch is turned on
- You are using alkaline (normal, non-rechargeable) batteries
Like @Best_codes said, I think you need to use alkaline batteries or the 18650 battery pack available via robotshop.com.
I see but the problem is I believe we are just not getting enough volts from the batteries, we’re using 6 double a batteries. Is there another pack that can hold bigger and better batteries?"
I find this discussion interesting because it reveals a lot of uncertainty about battery status. Shouldn’t there be a way build into the system to verify adequate voltage.
@Addon2
A USB cable usually puts out about 5 volts. 6 AA batteries is 9 volts. So it does not make sense that it only works when plugged in!
So, have you uploaded a code to the mBot Mega to turn the motors? Be sure to actually upload the code in upload mode, not just use live mode. Live mode only works when your device is plugged in.
Yes we’re uploading everything correctly.
It worked before then we added more code which caused it to stop working.
@Addon2 Did you add an extension for this, I’m assuming? Does the robot work with a fresh code and no extensions?
No, Idea really all we did was cut the power to the motors by 50%. The motors work fine now. If we unplugged the wires to two of the motors it would allow the mbot mega to run again normally.
