data values of the line sensor is mbot (mblock shown in the program) is "0,1,2,3."
Do you plan to modify the original value mblock program to be shown (the incoming light is reflected numerical value) on mblock of the line sensor for more accurate programming is no wonder.
Line tracer and one run mbot connected wirelessly when you create a scratch program as “mbot program” using the block when executed by uploading directly to the Arduino programming sources to upload the same way, but this behavior appears quite different. The tracer line should have a wireless connection to the state. Why line tracer robot Arduino can only upload?
Mbot linetracer sensro & linetracer coding method
astheboy
una
Thanks for your suggestion, we hired a whole software team to improve mBlock, your suggestion will be reflected to the team leader. If you have further suggestions, welcome to share on this forum. Thanks!
Una
