Here’s the video. Did I do something wrong? I reset the firmware with the Factory firmware using mblock 5. When in remote control mode, some yellow lights come on. The left turn causes it to turn, right does not, but they quickly reset to the 3 beep sequence.
mBot factory firmware is not working, strange behavior with beeping
Best_codes
@jtm
Make sure:
- The batteries are fully charged
- The motors are plugged in to the correct ports (not switched)
- The sensors are plugged in to the correct ports (ultrasonic, line following)
This is a strange issue, unless there is some firmware issue or one of the issues above I would suspect a defective mBot…
system
