I have a new mbot, and am trying to follow tutorial. I have downloaded latest mblock v3.4.5. i have connect the mbot via usb and updated the firmware, and then connected via the 2.4 g wireless dongle. I can select mbot(mcore) in the boards menu. but the mbot extension is not showing. when i use the extension manager i can see an mbot extension, but it is not added. when i try to add it i can navigate to the mbot folder, but there is no.json file. what do i need to do to get the mbot extension showing in the extension menu?
Mbot extension not present
tech_support
Hi the program block under mBot is the mBot extension.
Under Board, choose the mBot (mCore), you can see the program blocks:
