mBot Cheat Guide
Hello Everyone ! (^o^)/
After playing around with the mBot I ran into some common issues most people on this community have so I hope to write a little cheat sheet to serve as your reference guide in order to make the mBot programming a little easier for you!
  1. In order to program your mBot you will need to dowload the MBlock Software:
    http://www.mblock.cc/download/
  2. In the MBlock sofware:
    A. click on "Connect"
    B. Install Arduino Driver
    c. Make sure the driver is dowloaded
  3. Make sure you dowload the Driver needed as well: http://learn.makeblock.cc/driver_installation/
  4. To run programs on your Mbot you can connect via Bluetooth Make sure Mbot is on then in mBlock click:
    A.Connect
    B.Bluetooth
    C.Discover (wait awhile)
    D.bluetooth paired !
*note if you are not sure if the mBot is connected (in MBlock) you can always click on the “Robots” tab then you will see a little circle next to the word mBot green means it’s connected, red means it is not.
5… You do not need to connect the black USB Cable from the mBot to the computer in order to be able to run programs you have written in MBlock!!!
Just make sure your mBot is connected via bluetooth then: write your program then click on the program (it should turn yellowish) then it will run !
6… If you do want to upload the programs to the mBot via the Arduino you will probaly have to reset the mBot afterwards because the remote control & app will not be able to control Mbot anymore
to Factory reset the mBot do this:
A. Plug in the USB Cable to your computer
B. Click on "Connect" --> SerialPort
C. Wait a while until you see your USB cable COM Show Up in the Serial Port (For me my USB cable is COM 4)
D.Then Click on "Connect" again then you should see the "Reset to Default Program" show up click it
E. Wait until it's complete and your mBot will be reset! (so you can use the App  & Remote control again!)
