I brought a new mBot and am facing an issue which I need your support with.
Product Information: mBot - eCommerce version - with Bluetooth Dongle
Make Block Version: 5.2.0
From MakeBlock IDE, I am able to connect laptop with mBot device using bluetooth (Both with and without dongle). However the program is not executing. Same one liner program works when I use the USB cable.
Sequence of events:
- First time I used the mBot, I connected using Dongle and ran the programs (live) and they worked fine
- I saw there was a prompt to update the firmware which could be only updated using the USB Cable. And I did that.
- Post this step, the programs work on MBot only using the USB and not bluetooth. Please note there is no issue connecting MakeBlock with the device, it is just the program does not work.
Please help.
