oh, that’s sad. I cannot understand that mbot2, which is an upgrade of mbot, has less connectivity options. And also I could not read anywhere about that mbot2 does not have bluetooth connection from PC (without official makeblock BT dongle).
You say that if I am lucky I can have a non official BT dongle that works. Is there any known model in the market that works? Because after spending 200€ in mbot2 I cannot spend other 27€ in the official bluetooth dongle which simulates a usb connection…
I don’t understand why with android tablet I can connect directly through BT but not from PC, where you can even change BT drivers to make it compatible with several devices.
I can use usb cable, which is what I have been doing until today. But I think that every time y work with mbot2, I need to upload different versions of programs constantly, which means connecting and disconnecting cable several times. I guess that is not a good idea for cyberpie’s usb connector and for the battery after months. Am I right?
thanks!
