Mblock with Shield adafruit v23 moteurs 4 x 1,2 A Arduino
I would to know how use mblock with the Shield adafruit v23 moteurs 4 x 1,2 A for Arduino
I download and installed the library "Adafruit_MotorShield_V2_mBlock 1.0 /by Beforefly / uploaded at 2016-11-14 00:00:00 " from this website : http://www.mblock.cc/extensions/
but i don’t success to launch any motor on mblock with the extension
I have saw that’s Befrefly has written on informations "Before using this extension, you should install the library Adafruit_MotorShield_V2 in your mBlock first. "
But i don’t undsertand how to “install the library Adafruit_MotorShield_V2 in your mBlock first”
from this website
How install this “first” library ?
Where could i find programs exemples for this shield ?
Thanks for help
Eric
Hi Eric,
Not sure what do you mean.
mBlock can allow to add extension. If there is extension already, just download it.
Thanks for answer. With your answer, I understood that my problem is maybe only from mblock. I don’t success to use my adafruit card with mblock. I succeed to install the adafruit library but my programs don’t work on my hardware (arduino uno+adafruit motors shield) . I don’t understand how programming… nb : i succeeded many times to programming an arduino uno or an auriga card with mblock but, with this adafruit card, it’s another problem …
Is someone get a exemple of program on Mblock with an Shield adafruit v23 moteurs 4 x 1,2 A ?
Thanks
You can post a video or some pictures to show more details of the “non success”. Maybe some others have encountered similar issue before.
Hello
Adafruit MotorShield V2 extension doesn’t work
I have this error message
start processing code…
processing code by middleware of pinMode
avr-toolchain\bin\avr-g++ -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\Users\Public\Programs\mblock\resources\app\mlink-v1\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/src/utility" -I"avr-library/libraries/Wire/src/" -I"avr-library/libraries/EEPROM/src/" -I"avr-library/libraries/SPI/src/" -I"avr-library/libraries/SoftwareSerial/src/" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/utility/" -I"arduino-libraries/arduino/Esplora/src/" -I"arduino-libraries/arduino/Firmata/" -I"arduino-libraries/arduino/Firmata/utility/" -I"arduino-libraries/arduino/Keyboard/src/" -I"arduino-libraries/arduino/Mouse/src/" -I"arduino-libraries/arduino/Robot_Control/src/" -I"arduino-libraries/arduino/Robot_Motor/src/" -I"arduino-libraries/arduino/RobotIRremote/src/" -I"arduino-libraries/arduino/Stepper/src/" “C:\Users\Techno\mblock-avr\temp\build\code.cpp” -o “C:\Users\Techno\mblock-avr\temp\build\code.o”
Command failed: avr-toolchain\bin\avr-g++ -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\Users\Public\Programs\mblock\resources\app\mlink-v1\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/src/utility" -I"avr-library/libraries/Wire/src/" -I"avr-library/libraries/EEPROM/src/" -I"avr-library/libraries/SPI/src/" -I"avr-library/libraries/SoftwareSerial/src/" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/" -I"arduino-libraries/arduino/Adafruit_Circuit_Playground/utility/" -I"arduino-libraries/arduino/Esplora/src/" -I"arduino-libraries/arduino/Firmata/" -I"arduino-libraries/arduino/Firmata/utility/" -I"arduino-libraries/arduino/Keyboard/src/" -I"arduino-libraries/arduino/Mouse/src/" -I"arduino-libraries/arduino/Robot_Control/src/" -I"arduino-libraries/arduino/Robot_Motor/src/" -I"arduino-libraries/arduino/RobotIRremote/src/" -I"arduino-libraries/arduino/Stepper/src/" “C:\Users\Techno\mblock-avr\temp\build\code.cpp” -o “C:\Users\Techno\mblock-avr\temp\build\code.o” C:\Users\Techno\mblock-avr\temp\build\code.cpp:1:10: fatal error: Adafruit_MotorShield.h: No such file or directory #include <Adafruit_MotorShield.h> ^~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated.
arduino build failed.
Thank you for help
