The unit of protocol communication is frame.
- Request frame consists of head, length, index, action, module, data.
head: head of frame, 2 bytes, with value 0xFF and 0x55.
length: 1 byte, describe the length of data.
Index: request number, 1 byte.
action: command type, 1 for requesting sensor data, 2 for actuator command.
module: describe the module of this frame, such as encoder motor driver module(0x01), stepper
motor driver module(0x02), 1 byte.
data: data to be sent.
- Response frame consists of head, index, type, data.
type: 1 byte, data type. 1-byte, 2-float, 3-short, 4-len+string.
data: its length is determined by data type.
- Demo:
Control DC motor:
M1 port DC motor rotates clockwise with full speed: 0xFF 0X55 0x07 0x0 0x2 0x0A 0x09
short2bytes(255)
M2 port DC motor rotates counterclockwise with full speed: 0xFF 0X55 0x07 0x0 0x2 0x0A 0x0A
short2bytes(-255)
Short2bytes function is used to transfer short type data to byte array data.
Get data from ultrasonic sensor:
Request data of ultrasonic sensor from Port 3: 0xFF 0X55 0x04 index 0x1 0x01 0x03
Response data: 0xFF 0X55 index 0x2 byte byte byte byte(transfer 4 bytes data to
float automatically)
Resource:
Firmware source code: https://github.com/Makeblock-official/Makeblock-Firmware/blob/master/mbot_firmware/mbot_firmware.ino
