Mblock 5 support for IR Module attached to Orion
I can’t access the IR module for Orion in Mblock 5. It appears as a sensing option but is greyed out. I’m not a fan of Mblock 5 as it doesn’t support the Orion which after all is the control for the Ultimate and Starter kits.
Had an epiphany|| It works when you enter upload mode but not in Live mode. Makes it difficult to test the routine though…
The blocks for IR module is only supported on upload mode.
Change the mode then you can use it.
Thanks.
Thank you!
