Please some help with the latest version of Mblock 5.0, we installed it and it looks great more intuitive.
We were able to successfully connect our Ranger via USB cable.
But a even simple code did not make it through the compiler.
Building code…
Use middleware arduino
avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\mega" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\bramp\mblock-avr\temp\build\code.cpp” -o “C:\Users\bramp\mblock-avr\temp\build\code.o”
Command failed: avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\mega" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\bramp\mblock-avr\temp\build\code.cpp” -o “C:\Users\bramp\mblock-avr\temp\build\code.o” C:\Users\bramp\mblock-avr\temp\build\code.cpp: In function ‘void _delay(float)’: C:\Users\bramp\mblock-avr\temp\build\code.cpp:10:25: error: ‘millis’ was not declared in this scope long endTime = millis() + seconds * 1000; ^
arduino build failed.
regards,
Frank
