Thank you for mBlock for Linux
The installation on Ubuntu 16.04 + MATE perfect, the USB connection with Arduino UNO, without problems, uploading the program by “Upload firmware” was not possible
Any ideas?
mBlock 4 Linux. "Upload firmware" was not possible
Hi joseluis,
The mBlock 4.x is the experimental version, it does have some bugs. We have recorded this bug, thanks for your feedback!
Any logs, or error message? Please switch to the Arduino mode to see the logs at the bottom right, or run mBlock from the command line and paste the logs from the command line screen.
Hello. Thanks for your interest.
I attach the log:
Download the React DevTools for a better development experience: https://fb.me/react-devtools
Warning: Accessing PropTypes via the main React package is deprecated. Use the prop-types package from npm instead.
Warning: SerialConnect: React.createClass is deprecated and will be removed in version 16. Use plain JavaScript classes instead. If you’re not yet ready to migrate, create-react-class is available on npm as a drop-in replacement.
is Dialog :
undefined
is Dialog :
undefined
is Dialog :
undefined
state.project: Object
Failed to load resource: the server responded with a status of 404 (Not Found)
######close loader-wrapper
sendMsg:_app.sendMsg
sendMsg:loadRawExtension:Arduino
sendMsg:_app.readyForFlash
readyForFlash
mBlock中的socket: socketCommunication
来自后端的改变主控板的消息: Object
下面通过flash去改变主控板: me/mbot_uno
local storage: Array[1]
sendMsg:loadRawExtension:mBot
state init
++++++from bluetooth message: Object
serial finding ping…
serial finding pong…
connecting…
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
sendMsg:_app.getExt().callJs
call js
mBot
resetAll
Array[0]
seriall is connected: false
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
call js
mBot
resetAll
Array[0]
sendMsg:unitTestMsg
changeSerialConnectStatus false ************
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
call js
mBot
resetAll
Array[0]
sendMsg:unitTestMsg
connecting…
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
call js
mBot
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
call js
mBot
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:mBot
call js
mBot
resetAll
Array[0]
sendMsg:unitTestMsg
connect Model close!
serial not finding
下面通过flash去改变主控板: arduino_uno
connecting…
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
serial not finding
sendMsg:unitTestMsg
serial not finding
serial not finding
is Dialog :
undefined
action OPEN_LOCAL_PROJECT @ 16:50:50.956
prev state Object
action Object
next state Object
is Dialog :
Object
action UPDATE_PROJECT_FILE_STATUS @ 16:50:50.988
prev state Object
action Object
next state Object
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
seriall is connected: true
++++++++++++++++++++++++++发过去的数据:
Array[5]
sendMsg:unitTestMsg
sendMsg:_app.setProjectRobotName
准备请求后端接口setProjectRobotName: Object
flash 已经传过来了: Object
is Dialog :
Object
action UPDATE_PROJECT_FILE_STATUS @ 16:50:59.089
prev state Object
action Object
next state Object
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
Array[5]
sendMsg:unitTestMsg
is Dialog :
arduino mode
action changeStageMode @ 16:51:03.726
prev state Object
action Object
next state Object
sendMsg:_app.arduinoModeEnabled
Arduino Mode Enabled
sendMsg:_app.updateScript
is Dialog :
Object
action SHOW_PROGRESS @ 16:51:09.399
prev state Object
action Object
next state Object
is Dialog :
Object
action UPDATE_PROGRESS_PERCENT @ 16:51:09.403
prev state Object
action Object
next state Object
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
Array[5]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/.
刷固件返回的数据:
Object
is Dialog :
Object
action UPDATE_PROGRESS_PERCENT @ 16:51:12.559
prev state Object
action Object
next state Object
刷固件返回的数据:
Object
is Dialog :
Object
action PROGRESS_FAILED @ 16:51:18.637
prev state Object
action Object
next state Object
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
sendMsg:console.log
method:resetAll
sendMsg:console.log
ext:Arduino
call js
Arduino
resetAll
Array[0]
sendMsg:unitTestMsg
is Dialog :
undefined
action HIDDEN_PROGRESS @ 16:51:21.915
prev state Object
action Object
next state Object
serial not finding
serial not finding
Thanks for your answers.
I’m glad to hear that you found mBlock for Linux and the USB connection with Arduino UNO working well on Ubuntu 16.04 with MATE. However, if you’re facing difficulties uploading the firmware using the “Upload firmware” feature, there are a few things you can try:
Check USB Connection: Ensure that the USB cable is securely connected between your computer and Arduino UNO. Try using a different USB cable or USB port on your computer to rule out any potential hardware issues. Get more details - React JS Course in Pune
Select the Correct Board and Port: In mBlock, go to the “Board” menu and make sure that the Arduino UNO is selected as the target board. Also, verify that the correct port is chosen under the “Connect” menu. You can try different port options to see if it resolves the issue.
Reset Arduino UNO: Sometimes, the Arduino UNO might need to be reset before uploading the firmware. Press the reset button on the Arduino UNO board, and while the onboard LED is flashing, quickly click the “Upload firmware” button in mBlock.
Reinstall Arduino IDE: If the above steps don’t work, consider reinstalling the Arduino IDE. First, uninstall the current Arduino IDE from your system, then download the latest version from the official Arduino website and install it. Afterward, try uploading the firmware from mBlock again.
Seek Community Support: If the issue persists, it can be helpful to seek assistance from the mBlock or Arduino community. Many forums and online communities exist where users share their experiences and help troubleshoot specific problems.
