mBlock 3.3.3 and 3.3.4 works not with Me UNO Shield
Hi, I use an Arduino with the Me Uno shield and have found that at least the board does not work in the scratch mode with mBlock 3.3.3 and 3.3.4.
Me Orion works with 3.3.3 (3.3.4 not tested)
I can connect with the Board and upload the firmware well - but when I click the green flag, nothing happens.
With mBlock 3.3.0 everything works as expected.
Hi Gjb,
Thanks for your feedback.
mBlock 3.3.4 works with Orion board without any issue.
As for the Me uno shield with Arduino, normally it will work. We will give a test and let you know later.
Hi Gjb,
Do you mean that the program works ok after you uploaded it to the board with the mBlock 3.3.4 but doesn’t work when use the green flag?
When you use the mBlock 3.3.4, make sure that you have chosen the Board as Me Uno Shield, then select correct serial port. After that, please upgrade firmware for it under the Connect option.
After you upgrade the firmware, then please test above program.
I test the new 3.6.6 – it works fine.
The steps 1. select board 2. connect serial port 3. upgrade firmware I’ve done many times, and after updating to 3.3.4 has stopped working - but now I can not retrace it.
Thanks for support
Gerhard
Hi gjb,
Glad to hear that, thanks for your feedback!
