Hi, I have been trying for over 6 hours to get the mdraw software to run. I built the xy plotter, and tried to run mdraw. The problem is it WON’T HOME so I assume the calibration is off. When I run the print it just runs to the corners and continues trying to push beyond.
I tried everything with the limit switches. I changed, rearranged, etc. They appear to be working, as the readings in the settings change from 1 to 0 when pressed. But, the pen head will not move to a home location.
I’m not sure what else to do. I need to use mdraw (not familiar with the Arduino type of coding).
