Hi, we use on Arduino Nano Me Stepper Driver and a step engine.
We want when the movement team is executed to write the Mystepper.disableoutPuts () command;
But the motor is still holding a position. Food enters it. What are we doing wrong? An object of AcceelStepper Mystepper is announced (Accelstepper :: Driver, 9, 8); in Setup Mystepper.setenablepin (4); Specify PIN for EN. In the code we use mystepper.disableoutPuts ();
We also added, but the motor is kept still. Mystepper.Setpinsinverted (false, false, true);
Makeblock Stepper Motor Disable
bonny
bonny
And when you connect to RJ25 to MeOrion, then there is no output to SLP? There are two NCs there. Do they lead anywhere? Can I solder from one NC to the SPL output on the board?
