Hi, I was going through all the ports with the 7 - Segment display individually only to find out that the only port that will work is Port 3 (Which is labeled as Port 6 on the board for some reason). Ports 1-4 are coded to show up with their own numbers however Port 3 is the only one that does so. Is the product defective or am I supposed to go through additional steps to make more Ports work?
Makeblock Starter Kit - Only Port 3 works?
tech_support
7 - Segment display is labelled with Blue color, that means you can use port 3,4,6, port 5 is for hardware serial. And you can’t input the words “port1 or port2”, but select from the drop down list.
TibascoSauce
I try to plug in the 7 - Segment display to other ports along with other components that correspond with those ports, but only Port6 (Labeled Port3) works.
system
