Makeblock Orion Stuck in Loop - Please Help!
I was using the example MeLight sketch from the Arduino library.
Now the Makeblock is stuck in a loop. When I try to upload a new sketch via Arduino IDE, it says that the serial port is in use. The light is flickering. But I can’t get the sketch to stop.
Is there any way to delete the sketch from the Makeblock without using the serial port?
Hello
1.If you use Leonard board you should hand reset when download.
2. I think the first time in the download process avrdude didn’t finish nomally, this lead the Subsequent download failed, maybe you can try to turn off the avrdude process or restart.
Thanks
