Makeblock Laserbox driver for Mac OS Big Sur 11.0
Is there driver for Laserbox pro driver for Mac OS Big Sur 11.0? Kindly help.
Connecting laserbox machine with your PC,we had 3 methods,If USB cable connection get stuck,you can try to connect via wifi and Ethernet.
Here share the video for you to check how to connect via wifi and Ethernet.
Note:
1.If you want to use wifi method to connect with laserbox machine,then you must use USB cable or Ethernet to connect with your PC first,and input the wifi account and password for your laserbox machine,after that you can remove the cables and connect with the machine via wifi.
2.Once use wifi to connect with laserbox machine,your PC and laserbox machine must use the same wifi then can make it connect.
