Lossing conection
Im getting really frustrated…
My machine has lost connection about 10 times this mroning and now will not re connect …
what is the deal why is this happening.
I need it to work ASAP
Hi there:
which way you connect your PC to the laserbox,USB cable or WIFI network,if you use your USB cable to connect with your PC please follow these steps:
The reasons are more complex and diverse, most of which are related to the user’s computer environment (such as being blocked during driver installation, using proxy and other circumvention software, and historical firmware versions before 018 are not compatible with 10.13 and later Mac computer systems). The troubleshooting steps are as follows:
  1. Confirm whether to use the official USB data cable;
  2. When installing the software, close all anti-virus software and update the laserbox software and laser box firmware to the latest version. If the current computer cannot connect to the device to update, try to find another computer to connect; if there is no other computer available for connection, try to update with an SD card firmware;
  3. Close all circumvention software (100% cannot connect when the circumvention software is open);
  4. Wait for the machine to turn on. After the 6 ring lights are always white, then connect to the software (if 6 white lights cannot be turned on, it means the machine itself is abnormal), after the connection, there will be a beep, and the 6 ring lights will change. Blue
  5. Insert the USB before turning on the laser box, turn on the laser box, and connect to the host computer;
  6. Use a network cable to connect the device to the computer. If the Apple computer cannot be connected to the USB, you can use a network cable adapter to try to connect or use a windows computer to connect and configure a Wifi connection;
  7. If the above operations cannot be solved, try to install the driver
    Windows driver reference: https://makeblock.yuque.com/mkquality/yyl8ng/nf3xir#UwqZJ
    Mac drive reference accessories;
  8. After the Apple computer is upgraded to the latest system Bigsur, because the SIP protection system is turned on, it cannot be connected. You can manually close the SIP and try to connect again. The closing steps are as follows:
    a.Turn off your Mac (Apple> Shut Down)
    b.Hold down Command-R and press the Power button
    c. Wait for OS X to boot into the OS X Utilities window
    d.Choose Utilities> Terminal
    e.Enter csrutil disable
    f.Enter reboot
    g.Run the command on Terminal: sudo kextload /Library/Extensions/HoRNDIS.kext
