LED Panel with Text, takes no x value < 0
Want to program a text with changing x position. x should start from 0 and should go to -20.
The command “LED Panel” does not take negative x and y values. Only > 0 values.
I’m using mBlock v5.3.0.
I’m using the Ranger with “Maker es Platform”.
I also saw a video with mBot where it was working.
But obviously under ranger with “Maker es Platform extension” it’s not working.
Can you advise.09
It’s obviously only an issue in LIVE mode. Not when you upload code to the Ranger
Hi there: Can you send the program to lindingxin@makeblock.com,thank you.
