Laserbox Pro Sparks While Cutting
My Laserbox is spurting out sparks while cutting material and it has not done this in the past. The light coming from the laser is much brighter as well. I cleaned the nozzle and the mirrors with a rubbing alcohol solution and this did not solve the problem. I’ve had this machine since the beginning of January. Is this normal as the Laserbox Pro gets older or should I contact customer service?
more power more sparks !
don’t worry
When you low down the speed and increase the power,cutting the material like basswood there will have small sparks during the proccession,but laserbox with built-in Airpump of laser head so you don’t have to worry about that
