Laserbox not cutting correctly
My Laserbox does not fire all the time - so the lines are not completet.
See picture. What should I do?
If the device is on long enough, eventually the lines are cut correctly.
The SVG file looked like this
But it’s not the file - even a straight line created in Laserbox.exe or Xtool Creative Space won’t cut correctly, if the Laserbox is switched on recently (see lower line in following picture). Laser fires, then ceases to fire.
Then again fires…
After leaving the laserbox on for about 40 minutes, the same file with the same settings cuts a correct line (upper line in the picture).
Strange. Ho did the SVG files look when processed? Also see:
support@makeblock.com
and
https://support.xtool.com/.
@schmooke @Crackel
