Laserbox cutting performance
How thick can a laserbox cut an acrylic plate? Also, please tell me the speed and power parameters in that case.
Hi dai5_jp,
Laserbox can cut paulownia wood board of up to 15mm.
About materials, you can check from here.
https://www.makeblock.com/support/ps-laserbox
Thanks.
So, can laserbox cut a 10mm acrylic board? If so, please tell us the speed and power parameters.
Hi dai5_jp,
The laserbox will recognize the official materials automatically based to the ring code showed in below picture.
If no ring code, we have pre-set parameters for some materials in Laserbox software.
You can choose the correct material and it will give you the pre-set parameters.
If not the official material, you need to test and figure it by yourself.
https://www.makeblock.com/laserbox/
Thanks.
