Hi, the default settings are 95% for power and 20% speed for 3mm basswood.
This seems to me to be quite a lot of power. The edges are also very dark and there is a distinct yellow discoloration on the cut edges.
I can hardly judge the speed, since it is given in %. I have found a cutting speed of max 600 mm/s. Default is 20%, that would be 120mm/s. That seems to me very much.
Others typically use 15mm/s.
Does anyone know the true maximum speed?
Has anyone had good experience with other settings?
Greeting Holger
