Land Mode project
I want the hovercraft to move forward when my mobile device tilt forward, etc. after switching on the power button. But the hovercraft just keep moving forward. no other directions as expected.
Would anyone give suggestion to correct my coding?
Hi Simon,
The hovercraft may follow the command a little bit late after you set out the command on tablet.
And it doesn’t have the light flow sensor so that it cannot achieve precision hover but have a little offset when hover in the air. So the performance can achieve what we expect with the coding.
Thanks! That means my coding should be ok but just because of no light flow sensors for it to work?
Yes, but tablet direction detection is not very sensitive. And I suggest to land first and then power off.
Tablet coding in air mode would be better?
