Issue upgrading the firmware from 3.3.2 mBlock release
Hello everyone, today i received my new set of mBot robots, the first thing that i made was download the latest software for Windows, install it and try to ran a script from the IDE. I noticed when i was trying to turn on and off a RGD leds from the board that one of them not response, so the next thing i tried was upgrade tothe last firmware from the Connect menu->Upgrade Firmware.
Once the mBlock software finish to load the firmware to the mCore board of my mBot, i noticed that the board do not boots properly just a beep twice and no RGB leds sequence or classic tones after boot.
Then i tried to Reset Default Program->mBot with no luck
Thus, i have my board stuck
Has anyone have experienced this issue with the new release?
Thanks in advance
Hi Ubuntoscar,
I have tested the mBot on mBlock 3.3.2,
After upgrade firmware, tested turn on and off the RGB with below program, it works properly:
And it is normal that there is only a beep twice and no RGB leds sequence after Upgrade Firmware finished.
Normally, there should be RGB leds sequence with classice tones after finished reset default program.
Attachments are instructions to guide Upgrade Firmware and Reset default program for mBot, please double check if everything is operated correct(you can try move the bluetooth module or 2.4G module temporarily while upgrade firmwre or reset default program).Upgrade Firmware and Upload Program for mBot.zip (860.4 KB)
1.How to reset default program manually.docx.zip (404.1 KB)
